ORA-12899: value too large for column length while performing rules Upgrade (Step after rules migration).
Rules upgrade failed with below error while upgrading from PRPC 61 SP1 >> Pega 719
Log:
[java] Caused by: com.pega.pegarules.pub.database.DatabaseException: Database-General There was a problem getting a list 12899 72000 ORA-12899: value too large for column "RBSI_RULES"."PR4_RULE_RULESET"."PYLABEL" (actual: 67, maximum: 64)
[java]
[java] From: (A9892FDA977B1BDD156DD46C0F44BA93B)
[java] SQL: INSERT INTO RBSI_RULES.pr4_rule_ruleset (PXCREATEDATETIME , PXCREATEOPERATOR , PXCREATEOPNAME , PXCREATESYSTEMID , PXHOSTID , PXINSID , PXINSNAME , PXOBJCLASS , PXSAVEDATETIME , PXUPDATEDATETIME , PXUPDATEOPERATOR , PXUPDATEOPNAME , PXUPDATESYSTEMID , PYLABEL , PYRULENAME , PYRULESET , PYRULESETNAME , PYRULESETTYPE , PYRULESETVERSIONID , PYVERSIONSECURE , PZCHECKSUM , PZINSKEY , PZPVSTREAM , pxCommitDateTime) SELECT PXCREATEDATETIME , PXCREATEOPERATOR , PXCREATEOPNAME , PXCREATESYSTEMID , PXHOSTID , PXINSID , PXINSNAME , PXOBJCLASS , PXSAVEDATETIME , PXUPDATEDATETIME , PXUPDATEOPERATOR , PXUPDATEOPNAME , PXUPDATESYSTEMID , PYLABEL , PYRULENAME , PYRULESET , PYRULESETNAME , PYRULESETTYPE , PYRULESETVERSIONID , PYVERSIONSECURE , PZCHECKSUM , PZINSKEY , PZPVSTREAM , CURRENT_TIMESTAMP FROM RBSI_RULES.pr4_rule WHERE pxObjClass IN ('Rule-RuleSet-Version') AND pzInsKey NOT IN (SELECT pzInsKey FROM RBSI_RULES.pr4_rule_ruleset)
[java] SQL Inserts:
[java]
[java] Caused by SQL Problems.
[java] Problem #1, SQLState 72000, Error code 12899: java.sql.SQLException: ORA-12899: value too large for column "RBSI_RULES"."PR4_RULE_RULESET"."PYLABEL" (actual: 67, maximum: 64)
[java]
[java] at com.pega.pegarules.data.internal.access.ExceptionInformation.createExceptionDueToDBFailure(ExceptionInformation.java:262)
[java] at com.pega.pegarules.data.internal.access.DatabaseImpl.list(DatabaseImpl.java:6283)
[java] at com.pega.pegarules.data.internal.access.DatabaseImpl.executeRDB(DatabaseImpl.java:6676)
[java] at com.pega.pegarules.data.internal.access.DatabaseImpl.executeRDB(DatabaseImpl.java:6632)
[java] at com.pega.pegarules.data.internal.access.DatabaseImpl.executeRDB(DatabaseImpl.java:6613)
[java] at com.pega.pegarules.data.internal.access.Migrator.migrateClassInstances(Migrator.java:83)
[java] ... 33 more
[java] Caused by: java.sql.SQLException: ORA-12899: value too large for column "RBSI_RULES"."PR4_RULE_RULESET"."PYLABEL" (actual: 67, maximum: 64)
[java]
