Infosys Limited
Last activity: 8 Sep 2015 13:17 EDT
Logo is missing
In Google Chrome, Pega Logo and background is not displaying in login page .
i tried to resolve this by enabling the cookies but not succeded.
Also checked the Production-level. it is set to 4.
Please help me in resolving this problem.
Thanks in Advance.
Services Australia
Is this issue only with Chrome?
Have you tried other browsers?
Vamshi
Infosys Limited
Thanks for your reply.
Issue with other browsers also.
it must be an issue with skin rule. could you please run through the below queries ... and try to revalidate the rules to see changes...
select * from pr4_rule where pzInsKey like '%PZCSSINCLUDE_%';
select * from pr4_rule_file where pzInsKey like 'RULE-FILE-TEXT WEBWB PZHARNESS_%';
select * from pr4_rule_file where pzInsKey like 'RULE-FILE-TEXT WEBWB PZSKIN_%';
NIIT Technologies Limited
In my case, same issue was fixed after clearing temp directory and restarting the server.
Areteans Technology
It is definitely not because of skin as login page does not have skin related css. See your tomcat logs and see if the prweb war file is deployed correctly. Give a try to redeploy things. See the http traffic in the browser and see the failure reason for the images not being loaded.
Ashok
Infosys Limited
As Ashok said, redeployed the .war files ( prweb, prsysmgmt, prhelp). But the result is the same.
Please let me know, where i can get the logo image details in portal.
Thanks in advance.
Areteans Technology
Kishore, can you monitour your http network in your browser. also see logs when you hit the home page.
Did this ever work or is it the behavior from the first installation of Pega 7?
Is the login screen customized or the Home Directory in the access group modified?
Does the PRPC Temp location specified have enough memory and also the required permissions to read\write?
Paypal
Hi, We had similar issue with PRPC 7.1.7 on WebLogic 12c. Pega GCS has suggested to comment the following servlet mapping in PRWEB.WAR web.xml file
<servlet-mapping>
<servlet-name>WebStandard</servlet-name>
<url-pattern>/*</url-pattern>
</servlet-mapping>
and redeploying PRWEB.war in your app server will resolve this issue. regards Gobi
