Locked RuleSet
I am trying to add a simple Subcase and Configure Sep Bahaviour however, I am consistently getting an error message:
"The flow Default Step is unable to be edited because it is in a locked ruleset. Please unlock ruleset version."
I have doublechecked the Rulesets in:
-Application Stack
-Operator Profile
but I see no locked RuleSets.
I have created a brand new RuleSet version and it is definitely not locked.
I have even checked Postgress db table to confirm that RuleSets are not locked and that is definitely the case.
Any thoughts please?
When you create flows the case designer adds a step named "Default Step" (up to pega 7.1.7) and that step itself belongs to a locked rule set. What you need to do is to give the step another name, or replace it with anew step, before you go in and configure it. The new step will then be created in your own unlocked rule set
