Introducing Delay in File Listener
I know there has been a few discussions in the PDN about how a file listener (only one running on one node) would process the files if there are multiple files placed in the folder. My questions is whether it is possible to introduce a delay between the processing of multiple files in a file listener.
Scenario:5 files are put in the folder which is monitored by the file listener. Each file has a specific number of records. I would like to have the processing sequence as follows:
- FL1 picked up and the service file processes the records.
- there is a gap of a minute or so then FL2 is picked up for processing and so on
Is this practically possible in Pega? I have tried using the Idle Processing section but to no avail.
the only option I see is to have a job running on the OS where Pega is installed, and this job would send the file one at a time to the folder which Pega is monitoring.
any light in this direction would be very appreciated.
Hi Anoojit,
Looking at the FileListener code now and unfortunately i don't see any logic to put a delay in between processing of each file. Basically we just loop through each matching file in the directory and process the file one at a time without any delay. As you mentioned above, controlling it from the OS level may be the way to go for now.
=waikei
