How to track the rules changed as part of a User Story, is something available in Designer Studio?
  By enabling Project Management we could track the rule changes
or would creating a report definition on class 'Data-Rule-Summary' filtered on
Please share your thoughts, Thank you!
psahukaru
  Thanks for your comment
Few points to ponder
  Not sure of OOTB tracker tool/wizard as such available ... but again a report definition on Data-Rule-Summary could be helpful.
  Hi Sumit
How are you mainiting your User Story ar they Specification rules? If yes, then we can associate specification rules for Flows rules and Flow shapes to track implementation details.
However for defects, I do not see any OOTB feature available for the same. One approach is to use Defect ID as check in comment and then create a Report definition for pyMemo column.
Vamshi
  you could also think of having/adding Custom fields (on history tab of a rule form) if you don't feeling it doing as an over engineering just to track changes/for reporting purposes.
for tracking changes - please see https://community.pega.com/sites/default/files/help_v71/procomhelpmain.htm
