PL
Last activity: 10 Dec 2018 9:15 EST
How to create custom conversational channel action
Action is a primary component of command processing by MCP engine. List of actions is dynamically generated based on action class inheritance.
Action could be a very simple logic without any parameters or could be very complex.
Action is invoked with pyInteractionCase page context - developer is able to use his own properties from Work-Channel-Interaction-* class. Proper pyOutboundMessage structure is an expected output from each action and such outbound will be passed to application view’s endpoint.
There are two types of actions: common actions and channel-specific actions.
Common actions are stored in Embed-Channel-Action-Commons- class instances. By default, there are some common actions implemented:
- Cancel - cancel current work,
- Create case - create new case type,
- Menu - display available response options in menu,
- Restart - start current case from the beginning,
- Text - simple text response.
- Custom - data transform rule based response
Channel-specific actions need to be created in Embed-Channel-Action-<channel_name>-. For example, in FacebookChannel ruleset there is a channel-specific link account action, which gives the possibility to link Pega 7 operator's account.
Step by step guide
1. Create new abstract class rule:
- for common action: derived from Embed-Channel-Action-Commons,
- for channel-specific action: derived from Embed-Channel-Action-<channel_name>.
2. Save as pyCaption.ActionLabel (Embed-Channel-Action-) field value to your Embed-Channel-Action-*-* class and set proper action's label.
3. Save as pyPerformAction activity to your Embed-Channel-Action-*-* class and implement some logic:
- Primary page for this activity is a page taken from configuration, so it contains all properties set within particular configuration of channel which currently is processed,
- pyInteractionCase page is available to read the input and set the output.
Optional steps:
- Save as pyActionProperties section to create UI for action's specific properties:
- At this place you are able to extend Embed-Channel-Action-*-* model and create action's specific configuration properties,
- Default values could be placed in pyDefault DT - remember to call parent-class DT.
- Save as pyValidateAction activity when you need to add validation constraints on action configuration properties:
- Add any number of error messages to action configuration properties. When at least one error message exists on configuration page it cannot be persisted.
- Save as pyActionSummary section to override default presentation of action in grid. By default pyCaption.ActionLabel field value is presented.
- Save as pyOnLoad if you want to add some logic which will be invoked when action is added/modified within configuration.
- Field Value for property pyCaption with id ActionLabel which contains action's label:
- Section pyActionProperties to customize action configuration UI:
- Activity pyPerformAction to implement action logic:
ProcessingPage is only a parameter name, its value is always set to pyInteractionCase (Work-Channel-Interaction).
- Activity pyOnLoad to implement logic when action is added to configuration.
Action could generate multiple outbound messages and depending on what channel it is, it will be handled in a different way (i.e. FB sends multiple requests to Messenger and multiple messages are displayed to end user).
There is a single page pyMetadata, which includes the information used for choosing the correct rendering.
