Rabobank
Last activity: 31 Mar 2015 12:31 EDT
Hide required icon on read only mode
I have a requirement to hide the required icon when a section is in read only mode, i can't find the css definition that has that definition.
Doest anyone know where i can perfom this change?
Capgemini
Unless its a application wide requirement, I dont try to implement it as CSS level.
I will create another section in read only mode with out required icon and control when to show this readonly section.
--Bala
Rabobank
It is an application wide requirement. But for some reason every CSS i modified the change is not getting picked up
Capgemini
which CSS are you modifying ?
Rabobank
I tried with private edit pzBaseCore or EndUser but it didnt wor i'm trying to replicate the same actions that are in this article https://pdn.pega.com/customer-process-manager/how-to-restore-the-orange-asterisk-indicating-required-fields-in-cpm-62.
Capgemini
The article pointing in the right direction.
I doubt CSS chagnes works in private edit.. did you validated whether your modified CSS loading onto portal ?
If not, give it a try with regular edit, check in the code and clear server and client browser cache.
Rabobank
I did try with firefox i use the developer tools and in the CSS it does shows the modified CSS
Capgemini
When the modified CSS loaded on to Portal and still you see astric symbols on mandatory fileds means, either some other CSS overriding your changes or the changes you have done have issues executing..
Work reverse way... take source code from portal and see which is css showing astrics..
