EPAM Systems
Last activity: 16 Feb 2023 15:28 EST
Flow shape to call Data Transform
Hi Team,
Would it be possible to include utility like shape to call Data Transform from flow so that Data Transform and description would be visible from Case type and App studio.
Currently we can call Data Transform from connector but its description is not visible in the Case type.
This feature would help in readability of the business flow from the Case type and App studio.
Lalit
Updated: 27 Apr 2022 16:38 EDT
Hi @Lalit_Singh,
Thank you for sharing your idea here in the Pega Collaboration Center (PCC)!
I have submitted this idea on your behalf in our internal system for feature enhancements and updated your post with the associated FDBK-ID. You can view this in our internal system.
Thanks and keep the ideas coming!
EPAM Systems
@Kayla_M Thanks for creating the feature enhancements request and now I can see this has been completed in 8. 6.
Virtusa International B.V
@Lalit_Singh Hi, I am trying to use this 'Run Datatransform' shape in the flow. It has a dropdown to select the DT, but it doesn't show me any DTs that are created. Could anyone please suggest ?
Satya Teja
Contractor
@NarenV50I was trying to use the same functionality and I realized you need to mark the Data Transform you want to see there as a relevant record otherwise it won't appear on the dropdown
Mindtree Ltd
If you want to call DT through "Run Data Transform" shape within flow, first you need to mark DT as "Relevant Record". This option you can get it from Action Button of DT rule.
varnika gupta Keerthi Nunna Murali Kiran Bonam Vikash Jha Pawan Narain Singh
Heimstein
CH
@Lalit_SinghGood Suggestion. As a work-around, I sometimes use a utility-shape an, leave the configuration as "pyUtilityStub" and use the description of that.
Mohamed Uwais Mohamed Ilham
EPAM Systems
@Pascal.Hausammann Yes, We are also doing the same as work-around for now.
JPMC
@Lalit_Singh Have you tired calling the activity "pxCallDataTransform" from a uility shape?
Antony Lawrence R Pooja Palla
EPAM Systems
@BhanuPrakash_G Hello , Yes we were using some work around but now in Pega 8.6 we have a separate Automation shape called Run Data Transforms.
Sopra Steria
@Lalit_Singh So this is a pretty nice feature, does this already accept parameters in the most recent version you're running? If we have to set those in connectors, we're stilll using two 'shapes' to achieve the same.
EPAM Systems
@BasRulesMatter Yes, Shape is not asking for parameter and we are also still using two 'shapes' to achieve the same.
Samiran Manna Vikash Jha
