Date COntrol
I have an requirement to disable the past dates in the calendar from the current date?Can any one help to know how to acheive this in PEGA?
Hi Shahed,
Could you please share the PRPC version you are working on to achieve this.
Please ellaborate the question little more with the use case you are trying to solve. This would help us to investigate.
You can actually write a control with JSP, within which it checks if the getActiveValue() is a past value using the R-U-Fs and make the field disabled. If the check fails, you can keep it editable.
