PL
Last activity: 23 Jan 2026 6:16 EST
Custom Recents
Special thanks to Subhadip Das from Capgemini who co-created this article.
Introduction
The Recent items feature in Pega Constellation UI allows users to access their most recently viewed cases or items, enhancing navigation and improving the overall user experience. By default, Pega maintains a list of the 15 most recently accessed items, including cases, rule instances, forms, landing pages, and other elements.
While the default Recent items implementation works well for many scenarios, there are situations where customization is needed to better meet specific business requirements. This article explains how to create a customized Recents list that gives you greater control over what items appear and how they are displayed.
Important note here is that we adding a new user friendly way to interact with Recents while still keeping default server side processing and data preparation logic untouched. This solution is upgrade friendly.
Below is what we will achieve through configuration described in this article. Landing page (can be also a widget on Home page) with Recents showing more details about last visited item improving user experience.
Before implementing a custom solution, consider how you can improve the default Recents panel staying with solution that is out of the box. By default, the panel shows the case ID and label. If pyLabel is not customized, it displays by default the case name, which is the same for all case instance, typically this is not what you want. A popular use case is to override it and display business-related case ID as the label so your users can immediately know which case they want to open.
This might be everything that you need, and no customization needed. If you want to proceed with creating custom solution please keep in mind one important benefit of standard solution. Default Recents panel is always available on menu for the user allowing quick access to recent cases, without switching context. While implementing your custom solution as widget or dedicated dashboard consider to keep the out of the box one still available for users.
Why Customize the Recents List?
Customizing the Recents list allows you to:
- Filter the types of cases or items that appear on a list
- Add custom columns with additional information (by default you have only case id and label)
- Define number if recent records that you want to present
- Provide direct access to cases via clickable links along with ability to open preview panel
- Integrate the list with other elements of your application - have it a as a widget or dedicated landing page
Technical Implementation
The following steps outline how to create a customized Recents list in your Pega Constellation application:
1. Create a Data Page on work pool class
The first step is to create a Data Page on your case work class:
- Write a Data Page (list) on Case (work) class
- Make this Data Page accessible via API so it can be referenced by other components - set status of Data Page to API
2. Configure Report Definition
For the Data Page, use a report definition as the source:
- Set the source of the Data Page to a created report definition
- Create a new report definition on the Case (work) class
3. Configure the Report Definition Join
A key configuration here is to use System-User-Activity class. This is the class in which Pega stores recents items. The key to making this work as a Recents list is joining the Case data with System-User-Activity:
- In your report definition, configure a join with System-User-Activity
- Use the following join condition: Recent.pxResourceKey = Work.pzInsKey
- Add the order: Recent.pxUpdateDateTime DESC
4. DateTime Properties
There are two important DateTime properties to understand when working with a custom Recents list:
- Recent.pxUpdateDateTime: This property reflects when a user interaction with an item in the Recents list occurred. It's updated whenever a user adds an item to the list or interacts with it.
- Case.pxUpdateDateTime: This property reflects when the actual case was updated. It's updated whenever changes are made to the case content itself.
For a custom Recents list, the Recent.pxUpdateDateTime is more relevant as it tracks when users interacted with cases, not just when cases were modified. This is key for Recent functionality to work.
The descending (DESC) order is crucial because it ensures that the most recently accessed items appear at the top of the list, creating the expected user experience of seeing the newest interactions first.
5. Create a Landing Page
After setting up your Data Page with the report definition as its source:
- Create a Landing Page with template set to List Page that refers to our Data Page
- Configure the columns you want to display in this view
6. Apply "Display as Link to Object" on the Case ID Column
To make the Recents list interactive:
- In your view configuration, locate the Case ID column
- Apply the "Display as link to object" option to this column
- This allows users to click on items in the Recents list to navigate directly to the cases
Constellation 101 Series
Enjoyed this article? See more similar articles in Constellation 101 series.
