DXC
DXC
SA
DXC
Posted: May 3, 2016
Last activity: May 11, 2016
Last activity: 11 May 2016 5:15 EDT
Alert appears in Tracer when pyCaseTools runs
Hi colleagues,
I am facing an issue when ever the pyCaseTools section is called there is an alert appears in tracer which because of a visibility condition used in the "Follow" tab as "!pyIsFollowing". The following when rule is using a function called "@pzIsAFollower()". If i searched this function in PRPC it only shows the "pyIsFollowing" when rule.
The alert is also appearing because of "@pzIsAFollower()" as i can see.
Please help me on this to identify why the alert appears. Appreciate on your quick feed back.
Part of alert message.
" [MSG][Exception caught while evaluating when][STACK][java.lang.NullPointerException at com.pegarules.generated.pzIsAFollower_071017_mj4_Daq2cA14vq2nM4ZXFg.pzIsAFollower07_10_17(pzIsAFollower_071017_mj4_Daq2cA14vq2nM4ZXFg.java:106) at com.pegarules.generated.pzIsAFollower_071017_mj4_Daq2cA14vq2nM4ZXFg.invoke(pzIsAFollower_071017_mj4_Daq2cA14vq2nM4ZXFg.java:80) at com.pega.pegarules.generation.internal.library.LibraryRuntime.resolveAndinvokeFunctionViaReflection(LibraryRuntime.java:133) at com.pega.pegarules.generation.internal.library.LibraryRuntime.invokeLibraryRuntime(LibraryRuntime.java:110) at com.pega.pegarules.generation.internal.library.LibraryFunctionUtilityImpl.resolveMethodCall(LibraryFunctionUtilityImpl.java:3136) at com.pega.pegarules.session.internal.mgmt.Executable.resolveMethodCall(Executable.java:11018) at com.pegarules.generated.when.ra_when_pyisfollowing_c4acd81d79cdea1635eca6148cabd5ae.evaluate(ra_when_pyisfollowing_c4acd81d79cdea1635eca6148cabd5ae.java:50) at com.pega.pegarules.session.internal.mgmt.Executable.evaluateWhen(Executable.java:4229) at com.pega.pegarules.session.internal.mgmt.Executable.invokeWhen(Executable.java:10561) at com.pega.pegarules.generation.internal.stream.StreamToolsImpl.evaluateWhenCondition(StreamToolsImpl.java:1329) at com.pega.pegarules.generation.internal.stream.StreamToolsImpl.evaluateWhenCondition(StreamToolsImpl.java:1314) at com.pega.pegarules.generation.internal.assembly.jspwhen.JspWhenEvaluate.processElement(JspWhenEvaluate.java:230) at com.pega.pegarules.generation.internal.assembly.jspwhen.JspWhenEvaluate.processElement(JspWhenEvaluate.java:147) at com.pega.pegarules.generation.internal.assembly.jspwhen.JspWhenEvaluate.processElement(JspWhenEvaluate.java:147) at com.pega.pegarules.generation.internal.assembly.jspwhen.JspWhenEvaluate.evaluateCompiledWhen(JspWhenEvaluate.java:60) at "
