Bank of America N.A
Last activity: 23 Sep 2022 15:40 EDT
After the upgrade we are having some problems with cert handshake with this error javax.net.ssl.SSLHandshakeException .
We just upgraded PEGA from 8.3 to PRPC-8.5.3-551
its happening in connection with Mulesoft as well the full error stake is indicated in the attched file. I have the PEG-rules logs attached. so also the SystemOut.logs form WebSphere Proprietary information hidden
System Properties os.name Linux os.arch amd64 os.version 3.10.0-1160.76.1.el7.x86_64 java.version 1.8.0_321 java.fullversion Proprietary information hidden - pxa6480sr7fp5-20220208_01(SR7 FP5) JRE 1.8.0 Linux amd64-64-Bit Compressed References 20220104_19630 (JIT enabled, AOT enabled) OpenJ9 - 2d4c7d9 OMR - 59845b7 IBM - 3c151c1 java.vendor IBM Corporation java.vendor.url http://www.ibm.com java.vm.name IBM J9 VM java.vm.version 2.9 java.vm.info JRE 1.8.0 Linux amd64-64-Bit Compressed References 20220104_19630 (JIT enabled, AOT enabled) OpenJ9 - 2d4c7d9 OMR - 59845b7 IBM - 3c151c1 java.vm.vendor IBM Corporation java.vm.specification.vendor Oracle Corporation java.specification.name Java Platform API Specification java.specification.version 1.8 java.specification.vendor Oracle Corporation java.runtime.name Java(TM) SE Runtime Environment java.runtime.version Proprietary information hidden - pxa6480sr7fp5-20220208_01(SR7 FP5) java.compiler j9jit29 java.home /hosting/products/binaries/nd Proprietary information hidden_r01/java/8.0/jre java.util.logging.manager com.ibm.ws.bootstrap.WsLogManager java.io.tmpdir /tmp PegaDatabase Information
