Ading Section inside a Section
When I try to add a section under SAE-HRServices-Data-HRPlan to another section in SAE-HRServices-Work-BenefitsEnrollment, I get an error saying -
** Problem executing pzAssemblePreprocess for RULE-HTML-SECTION SAE-HRSERVICES-DATA-HRPLAN HEALTHCAREBENEFIT #20160225T202130.660 GMT
java.lang.NullPointerException
In general, can we add any section in any class in another section? or is there something like, a data class section could not be added to a work class section...?
Sudha.
Every Section needs a page to pull values from as it is rendered.
What page did you specify as the context within which your SAE-HRServices-Data-HRPlan Section is supposed to draw?
Guessing you wanted to use some case-embedded page, e.g., ".MedicalPlan".
When adding your SAE-HRServices-Data-HRPlan Section to a SAE-HRServices-Work-BenefitsEnrollment Section you need to specify:
