Limit file size per attachment category
We have a client requirement to limit attachment size per category. We've evaluated the DSS that handles file size and trying to change it per category also modifying some OOTB features to support this somehow, but it is not as dynamic as we need it to be.
We are considering alternatives such as evaluating the size of the file either once it is uploaded or from the CallVirusCheck activity and building validations from there, but we would like Pega's suggestions to achieve this in a simple manner without customizing OOTB rules or compromising performance.
We've seen support entries related to evaluating file size on upload for our alternatives but Pega has removed the content recommended, for example https://support.pega.com/question/how-get-attachments-file-size
Thanks.
@DaliaP16
Assuming you are using Cosmos Traditional UI (things might be a lot different if you are using Constellation) and any of the following controls for the Upload and selection of categories:
Attach content control
Manage recent content control
Every time you upload a file (by selecting from the dialog or Drag and Drop) and before you submit the dialog, the Page dragDropFileUpload will be available on the Thread, you could build an RUF (as described on the first link of your original post) to calculate the file size and then Validate according to your business needs.
Remember that Cosmos uses 2 threads when working on Work Objects, so you might need to switch between them to find the correct page.
@DaliaP16
