Capgemini
BR
Last activity: 29 Feb 2024 7:53 EST
Referencing Data Transform - Attempting to access a rule with a bad defined-on class
We identified a major issue after migrating our version of Pega 8.6.1 to 8.6.6. When we configure a data transform rule, which needs to reference another data transform, when we indicate the parameters to be passed, we find that it cannot locate it and the following message is sent:
Exception Message
Attempting to access a rule with a bad defined-on class: Trying to open rule "<<<<NAME OF RULE>>>>>" of class "Rule-Obj-Model", but no defined-on class (pyClassName) was specified.
We can locate the data transform if we access the tab directly to trigger the rule
What we should to do ?
