HTTP connect execution failure: java.net.NoRouteToHostException: No route to host (Host unreachable)
My Connect Rest rule is throwing "HTTP connect execution failure: java.net.NoRouteToHostException: No route to host (Host unreachable)" error. The endpoint URL is working fine in Postman without any issues and returning expected result but from Pega when I test connection using Connect Rest rule, Execute GET request for remote service was failed.
Pega Platform version : 8.5.6
Thanks in advance.
Hi @Vinoth: From the server check if the target host is reachable. You can use ping / telnet to check the connectivity. From the error it seems like the host which you are trying to connect is not reachable from the server where PEGA is running.
Thanks.
