SQL Query Consistently failing due to Syntax Error (Table: pegadata.pr_data_recents)
We are seeing this particular query consistently filing with the following error message:
Incorrect syntax near the keyword 'UPDATE'
The query in question is below. This is an query generated internally in Pega by web nodes. Please let us know what module this query is being called and if there is a fix.
Query attached.
@max_null I am unable to see any attachments. Could you please attach again?
Can you also clarify: is the query failing?
Can you check the pegaALERT and RULES logs and find out what processes or activities you see in the logs before and after the 'update' error?
