Frequently executed declare expressions
HI,
is there a way to find frequently executed declare expressions in the system? I checked Rule usage and Rule-Usage-details, couldnt find declare expressions there.
Thanks.
@pratapv5
You can check the declare expression rules for your application from the declartive network option which is there in the configure menu. Click on configure and navigate to the delcarative network. Choose the application and then you can see the declarative rules.
It displays the resultant declare expression properties. Open any of the property and check the references of it.
