Cosmos-React pop-up/modal windows more opacity
Greetings. Hope you are doing well! I am on Pega 8.7.0 and is having a cosmos-react app however when i launch any modal windows like Add Files from Attachments or launching a modal to select Primary Fields or even when launching a local action, i see the window as see-through (see image for reference). Any ideas as to what is causing this? Normal modal-windows launched from Pega (not part of Cosmos-React) are working fine.
Any one has see similar behaviour?
@RichardMarsot - Hi, Greetings. Please look into it when you get a chance.
Bharat
@KOMARINA you might have overriden the OOB default Cosmos theme - look at the article tag with role='dialog' - it likely does not have any background color - it should be set to your default background page color (by default white) - try to set back your theme for the channel to use the default Cosmos theme
