BA Continuum India Pvt Ltd
Last activity: 23 May 2022 7:29 EDT
How to setup SSO login between two different pega application
Hi, we are working on an application built in the Pega platform which is using the typical SSO / Ping authentication. To allow external users to access this application we will be routing traffic through ZTNA, since these external users do not have access to VPN. in short, user access application 1 without VPN and then it redirects to application 2 After having SSO configured in both application, the issue we are facing here is, we get SSO page of both the application and we have to login with multiple SSO authentication to complete the login. I have attached you the screenshots for reference. Could you please advise how we can reduce the multiple SSO logins between different application by setting up a SAML connection between these two application.
