British Telecom
Last activity: 7 Jan 2022 4:04 EST
Record count in report definition
I am using a custom section inside a report definition to show certain data in report browser.
The filter of the report is equal to a single instance in the class.
Now every time I am running this report along with the custom section with all the values and I am seeing a record count of 1 due to filter match.
Is there any way the count can be hidden, as the custom section holds multiple rows.
Thank you in advance.
@swarnaliD2401 Can you please elaborate or share a screenshot ?
The report viewer does exactly this. I would use this as a model. I believe it uses an embedded OOTB section pzDisplayRecCount.
Otherwise, the record count can be found on the pyReportContentPage on the clipboard (pxRecordCount).
Chandan U
