Accenture
BR
Last activity: 8 Jul 2020 12:01 EDT
Service Cliente Error
Hello, how are you!
I had a problem with one of the automations, where due to a problem in the service client we are not able to open the automation. We have already redone the automation but the same problem occurred later.
Following are images of what happened.
Could you help me please?
Thank you very much in advance
If you are using the ServiceClient, it creates a dynamic assembly that needs to be present on your machine. If you have access to the machine and user who created the automation, the file should be located in %AppData%\Pegasystems\DynamicAssemblies. That file needs to be present for any developer to open the automation that uses it.
