Importing external jar files application - > Distribution - > Import
HI team,
i have import certain third party jar files into pega using application -> Distribution -> Import and restarted system.
After importing jar file using above mechanism, we observed slowness in system
Hence want to check if importing third party jar files like Spring , javax.transaction-api,javax.activation-api-1.2.0 etc , will it impact pega application functionality like persisting Cases , rules etc
It could potentially break certain features if your jars are conflicting with Pega OOTB jars. You should disable or remove those jars to confirm. The jars you listed are generic and likely to be conflicting with those of Pega's.
