Barclays
Last activity: 8 Jan 2020 1:50 EST
Repeat Grid/ Table Layout Row Refresh Issue
Hi, I have a Table Layout having few columns (having dropdown and text input controls) and there is some data dependency between few columns. Inline edit mode is set to "click row to edit" and I have configured "Double Click" event to make the rows editable again if row was focused out.
Now since there is data dependency between few columns, I have been trying to use "Refresh row" action with "Change" event but the problem I am facing is, the moment I am selecting any value from say column-1 and row gets refresh, it updates the value in other column and required fields but the row goes to read only even though there are few columns left which are mandatory.
Not sure if I am missing any configuration here. Appreciated any help. Thanks
Pega Platform 8.1.0
If I have understood your requirement correctly, below are my response.
Hope this helps!
Geeda.
