Ford Motor Company
Last activity: 24 Jun 2019 9:36 EDT
Automating Mainframe applications using Pega RPA
We are trying to automate Mainframe applications using Pega RPA. We are using HostonDemand.exe to capture the text. I have added one Windows application and in the PATH, I have mentioned HostOnDemand.Exe. When i click on "Start interrogation", HostOnDemand is started but Interrogation is stopped immediately.
***Edited by Moderator: Lochan to branch reply into a new post***
Could you please help me to capture the screenflow for IMS mainframe applications.
Thanks in Advance.
Veera
Does the Robotics Studio throw an error when it stops the interrogation or are you able to see any errors in the log files? Is the .exe file available locally, if you tried to open it manually does it open normally? It may be how you set the path for the application file. Could you attach a screenshot of that from the properties window? The path typically should include the entire location so if it were on your desktop the path would look like "C:\Users\username\Desktop\hostondemand.exe" or whatever the exact path property is of that application
