Icewall SSO
Has anybody implemented a system using Icewall SSO? If so, are there any particular issues to watch out for?
No experience for Icewall with Pega integration. But if you simply use it as an IDP, it should be pretty simple in theory. What is the use case here in terms of Icewall/Pega integration?
