DHL
Last activity: 10 Jul 2019 4:19 EDT
Unable to connect to Kafka client using Data-Admin-Kafka instanc
Heloo,
Anyone configured Kafka client in pega 7.3.1.We are getting below error when we tried to connect to Kafka client using kafka Data-Admin-kafka instance.
Error connecting to Kafka. Failed to construct kafka consumer. java.io.IOException: Configuration
Steps followed:
1.Created a Data-Admin-kafka instance
2.Provided host name, port, keystore, truststore, pwd
3.Use authentication Kerberos.
4.JAAS config and krb5.config files passed in the java argument
Connection failed Error connecting to Kafka. Failed to construct kafka consumer. java.io.IOException: Configuration Error: thanks in advance.
Heloo,
Steps followed:
***Edited by Moderator Marissa to update platform capability tags**** |
Updated: 21 Feb 2019 9:23 EST
Hi ,
While creating the Kafka conf instance, we are getting the "time out expires while connecting to kafka metadata" error. We are using kerberos authentication in our organization. we have placed the Kerberos file and keytab file in server and also added those file paths,principal names in standalone.xml file.
Please let us any other things to be done for the kafka connection.
Roja
Standard Charted Bank
Hi RojaLakshmiM,
Can you provide the following details to help you out?
- Application Server
- changes made in JASS.conf file
hi Saravanan,
We are using Pega 7.4 version.
We have made the below changes in the JAAS file:
KafkaClient {
com.sun.security.auth.module.Krb5LoginModule required
doNotPrompt=true
useTicketCache=true
principal="bdplantview" ##<--Changed to our Principal
useKeyTab=true
serviceName="kafka"
keyTab="/home/araghava/kafka/bdplantview.headless.keytab" ##<- Updated this with the location of your keytab file
client=true;
Hi Roja,
Everything looks good except this principal="bdplantview".
In our case, I gave it like this "[email protected]".
In this, ABC.XYZ.COM is our default realm which I got it from the KRB5.conf file.
Please check your krb5.conf file and look for an entry like default_realm.
Ex: If the realm is set as "default_realm = ABC.XYZ.COM" then you need to set your principal name as principal="[email protected]"
Note:
If you make any changes in JASS file then server requires a restart to make it effective.
Hi Saravan,
Thanks for your reponse.
We had given the Principal name as "ABC@HDP_XYZ.COM" where "HDP_DEV.XYZ.COM" is the default_realm in KRB5.conf file, still we are not able to connect to the Kafka, getting the Time Out expires error. Also,Is the JAAS file configuration necessary to set up a connection? Though the JAAS file is placed in the location, on the kAFkA config rule form we see "No JAAS configuration ruleset". Please let me know any other changes to be done from the app server side for establishing the connection.
yes, JASS configuration is required. It seems your JASS config file path is not added to JVM arguments.
You need to ask your Application server admin to add the following into the JVM args.
-Djava.security.auth.login.config="/<FOLDER NAME>/jass.conf"
Also, you need to add your krb5.conf file path into JVM args as well.
-Djava.security.krb5.conf=/<FOLDER NAME>/krb5.conf
Once done, you need to restart the server. After the restart, you can verify that from SMA --> System Management
Hope, it helps.
DHL
After adding JAAS Config file and Krb5 file to JVM arguments , connection is successful.
Hi Sivajyothi,
Please tell me where exactly the JVM args should be added. f
Hi Saravan,
By passing the JVM args, its picking the JAAS file. But still getting the error "Error connecting to Kafka. Failed to construct kafka consumer. javax.security.auth.login.LoginException: Unable to obtain password from user.Unable to obtain password from user"
Please help me on this..
Hi Roja,
It seems the keytab file is not having the correct file permission. It should have 664. Please set and try again.
Hi Sarvanan,
We have successfully established the connection in our Dev env. But we are getting error while trying to connect to QA Kafka cluster from our QA env. Please find the attached screenshot and suggest what changes are required to establish the connection.
All the configuration like placing keytab,kerberos,Jaas file and changes to standalone file are done in QA server, still facing the issue.
Roja
Hi Roja,
Make sure that KAFKA user is added to QA Kerberos database.
Saravanan M
Hi Saravan,
Thanks for the help. We have successfully established the connection by following the steps that you have provided.
Roja
Zensar
Hi RajyaLakshmi,
Can you please explain me the detailed steps to implement Kafka Connectivity in Pega .
Thankyou
Hi Saravan,
