AXA ASIA
AXA ASIA
HK
AXA ASIA
Posted: Jan 21, 2019
Last activity: Jan 22, 2019
Last activity: 22 Jan 2019 20:26 EST
How to Remove "Appearance and Summarize" options from the report definition? pega version 7.3.1.
Hi Abhishek,
I think we cannot hide the those option, its coming from below navigation, its final rule:
Otherwise, if you want to hide the all the options, then we uncheck the Enable column command menu option under user action in Report viewer tab of respective report definition.
Hi Praveen,
Thanks for your response. We need to use show other options and only have to remove Appearance and Summarize from the option.
