Bix Extract from Work History without using BLOB
I need to perform a BIX extract from the workhistory table that contains 100 millions lines. (After an initial extraction, we'll use the PEGA Purge tool to reduce the amount of data in the database, but we need an extraction first)
The property needed are :
- pxAddedByID
- pxTimeCreated
- pyMessageKey
- pyPerformer
All that properties are exposed so use of BLOB is not necessary.
However, PEGA keep using pzPVStream while extracting and that take too much time.
We use PEGA 7.1.9. is it possible to force PEGA to not use that BLOB column or to delete the BLOB column in order to perform a faster BIX extraction ?
If we only have exposed column to extract, is it usefull to use BIX or not ?
Thanks.
Extraction of data from non-BLOB based tables is possible from 7.1.9 onwards.
Please refer below discussion
https://collaborate.pega.com/question/it-possible-extract-data-using-bix-table-without-blob-pzpvstream-column
https://pdn.pega.com/community/pega-product-support/question/bix-extraction-table-no-pzpvstream
