DXC Technology
BE
Last activity: 14 Sep 2018 4:16 EDT
Jar imports to load quicker
Dears,
Are there ways in which importing jars can be made to run faster.
I have a rules jar of almost 50 MB and its taking a long time to even cross the first two steps in the import GYI wizard before goes on to load. It then slowly starts to import itself with some info on some missing prerequisites which are not affecting the app in any way but any help to quiken this process will be helpful.
Any imporvements in this area is well received.
regards,
Jagan
The most important thing is running the import as close to the Pega server as possible. If you're on the same physical network as the server, you should see ideal speeds. If you're remote, you'll see slower speeds. There's not really anything software side that controls the speed of this, as far as I know.
