Practice Exam Question wrong?
In the practice exam question for Senior System Architect the following situation is described:
Isn't this answer incorrect? Because the rule instance in RulesetC is withdrawn in a higher ruleset (C) version (1-17-99) for the same apply to class. Conform the working of a withdrawn rule, all the rule instances in the same Major rule set version and apply to class are revoked. That would mean, the rule instance pointed as correct answer shouldn't be available.
Or am i missing something else here?
That would be true however the user does not have access to Ruleset C:01-17-99. They only have access to RulesetC:01-17-50, so the rules are not withdrawn.
Sean
Pega Academy Self-Study Support Team
