Obj-validate is causing field level errors on top of the screen and screen going blank
I am using a screen flow , in one of the flow action in validation tab I am calling a validate rule. Validation is working fine but the field level errors are being shown on top of the screen and screen is also getting blank.
Please help me understand why field level errors are showing on top of the screen. I am using "TabbedScreenFlow7" Harness. I am attaching screen shot of Display options tab as well as error on the screen.
I am on Pega 7.3.
Regards
Amit
Hi Amit,
The required validation that is shown on top of screen can be form-level validation as configured in Obj-validate rule as shown below:
If required option is checked in your validate rule, then the form level validation "This field may not be blank" will be shown on top of screen.
"TabbedScreenflow7" harness rule display options are as below:
Hi Amit,
Is this the same configuration at your end or am I missing anything here?
Share the screenshot of your validate rule condition that is configured in the flowaction.
Thanks.
