Booz Allen Hamilton
Paragraph text is not wrapping when added as section inculde in a Tree grid, in IE
Hi
In the requirement we have a tree grid, in which one of the column has a section include. In the section include we have a paragraph in one of the layout. As suggested, tried adding the word-wrap:break-word in the inline style of the paragraph rule and also tried adding to the Css file. Both did not work. Please let me know I there are any other options. I also see that hotfixes are also applied in few cases. The version used is 7.2.1.
Thank you
Hi
You mention IE as the browser. I am guessing that the issue exists while using Chrome as well. Could you confirm?
Could you attach screen shots of your configuration and what the run time UI looks like? Do you have really lengthy text in your paragraph rule?
Bhuvana.
Is it necessary to have a paragraph rule within your section?
Booz Allen Hamilton
The need to have it have in a section, is that there are 2 more buttons within the section to be included. Note: The paragraph text gets wrapped when not placed in the section. Any other alternate solution?
Booz Allen Hamilton
Hi
The paragraph rule that is placed in the section is customized as the Title property has to change its style on certain condition and added tooltip . It wraps correctly in Chrome. I tried added style="word-wrap: break-word" in the span tag that is used in the custom code, but still does not work.
Thank you
Paypal
i faced a similar issue.. and i used word-wrap:break-word;white-space:normal; in the cell inline style in Advance Presentation Option. it worked for me. Happy Coding :)
Booz Allen Hamilton
Hi
I tried the above codes but did not work in IE.
Accenture Pte Ltd
SG
Hi, is there any solution to this issue?
Try adding extra CSS apart from the mentioned above:
display:inline-block;
