How to handle wrapping in Tree Grid
Tree Grid is generated using two td's in outer layout. First td holds the first column and all the rest of the columns under one td as a sub table. we have rows which need word wrap and spanning multiple lines. where as the first column has only check box. which is leading UI distraction. could you please suggest work around?
