ING Belgium SA NV
BE
Last activity: 22 Mar 2018 7:56 EDT
Oracle migration issue : NL Exception was generated DSRA0010E: SQL State = 08006, Error Code = 17,002
We recently created new oracle DB setup(of oracle of version12c) in sandbox environment. When we tried restarting the server, could not access the designer studio and could see below error message in systemout file.
java.sql.SQLRecoverableException: IO Error: NL Exception was generated DSRA0010E: SQL State = 08006, Error Code = 17,002
Kindly advise what could be possible error for this.
Please note that we have copied db tables from dev and imported in sandbox environment.
Hi Nagaraj,
This error might be due to Syntactical errors like double quotes etc.. in Data source tag. Please check the Db connection Parameters for your new Database in "Context.xml" file or where Db URL is specified along with username and password.
Hemanth
