Accenture
Last activity: 16 Mar 2018 0:23 EDT
how to get a close icon in Smart Tip?
How do i get a close icon to the upper right corner of the smart tip?
I have the requirement that it should not be closed when i hover outside. It should get closed only on click of close icon. Please suggest.
Accenture
This is for Smart info. But i need for Smart tip.Any help please!!!
Is there any reason why SmartTip cannot be replaced be SmartInfo in your use case. I tried to check if there is any OOTB way(using SmartTip) in which this can be achieved, but could not find it since we may need to override pega_ui_harness_deferred which contains js files that are final.
Let's wait for other comments.
Luxoft
Hi Rachit,
We had an issue in showing the smart info. Our design is in repeating layout in a modal dialog we have to show the smart info on click of a link. We had some data page exceptions so we redesigned to have a smart tip instead of smart info. But smart tip has some limitations which we are trying with different style formats. No luck yet.
Can anyone help please!!!
J.P. Morgan Services India PVT Ltd
I am able to display a smart info in a modal dialog which is shown from a repeating grid, that smart info is configured on a link click.
what is the data page exception you are getting in smart info,
also which kind of limitations you are addressing in smart tip, please share the approach you want to follow so that accordingly we can guide you.
Thank you
Luxoft
Hi Neha,
Please find the below limitations :
1. No Close Icon at the top right corner of the window
2. When I hover out of the link, the window will be auto closed.
If i can overcome these, then the look and feel appears as smart info and that will be agreed by my client. There is an issue for us to use the smart info somehow. We tried various ways. My design is i show a repeating layout on click of link. and in repeating layout i see a tabbed layout and in that tabbed layout i have the smart tip link.
I cannot paste the issues now sorry as we have changed the design already and made the changes. We have our code in UAT already. I can say we were getting data page exceptions. Hence i was looking for the Smart tip limitations to be overcome if there is any possibility.
Thanks. any help further much appreciated!!!
May be you can consider using an overlay on click of link , instead of smart tip for your requirement. Overlay will not be closed unless you click away, and you can configure your own section to display the content in it even an icon to close it.
Hope it helps.
Thanks.
Luxoft
Thank you Sreepriya for an alternate approach. Will try it out.
Thank you all for the solutions.
See if this approach still applies/helps. It was written back in the 6 series, but some of the approach may still be relevant.
https://docs-previous.pega.com/troubleshooting-smartinfo-pop-window-remains-open-does-not-close-automatically
