Infomatics Corp
Custom Modules are not recognized during the build process
We are trying to upload the custom module for the android build in Pega 7.2.1. During the build process in the logs we observed that the custom modules are not getting recognized and they are getting ignored.
Below is the procedure we have followed to upload the assets to Pega Application.
1. Downloaded the assets.zip file from PDN.
2. extracted the Zip file and Included the android-module folder.
3. Uploaded the Zip file with custom module folder.
Below are the logs seen in the pega application. Please let me know if we are doing anything wrong while importing the custom module/does the build process expects the zip file contents to be organized in a specific folder format?
Unrecognized file/folder of assets/modules-android/customModule/src/main/assets/extensions/com.pega.scm/scm.js has been found in customization.zip and will be ignored.
I have attached a sample zip with only an Icon and sample android module inside. Please test with that. I was able to upload it as an assets folder. Note that custom module should correspond with version of mobile client used by Build Server. So if the build itself will fail you should check the Build Server logs (or request support to do so.)
ALeksander
