Error While doing test connectivity for MQ Server
Hello All,
We have configured one MQ server with required details and doing the test connectivity. But getting below error:
Failed to compile generated Java com.pegarules.generated.activity.ra_action_validateinfrastructuremq_a4456390d5ac62291bddd3f19a033d1c: ----------
1. ERROR in /com/pegarules/generated/activity/ra_action_validateinfrastructuremq_a4456390d5ac62291bddd3f19a033d1c.java (at line 392)
com.ibm.mq.MQEnvironment.properties.put(com.ibm.mq.MQC.TRANSPORT_PROPERTY,com.ibm.mq.MQC.TRANSPORT_MQSERIES_BINDINGS);
com.ibm.mq cannot be resolved
2. ERROR in /com/pegarules/generated/activity/ra_action_validateinfrastructuremq_a4456390d5ac62291bddd3f19a033d1c.java (at line 392)
com.ibm.mq cannot be resolved to a variable
3. ERROR in /com/pegarules/generated/activity/ra_action_validateinfrastructuremq_a4456390d5ac62291bddd3f19a033d1c.java (at line 392)
Hello All,
4. ERROR in /com/pegarules/generated/activity/ra_action_validateinfrastructuremq_a4456390d5ac62291bddd3f19a033d1c.java (at line 393)
com.ibm.mq.MQEnvironment.userID = username;
5. ERROR in /com/pegarules/generated/activity/ra_action_validateinfrastructuremq_a4456390d5ac62291bddd3f19a033d1c.java (at line 394)
com.ibm.mq.MQEnvironment.password = password;
6. ERROR in /com/pegarules/generated/activity/ra_action_validateinfrastructuremq_a4456390d5ac62291bddd3f19a033d1c.java (at line 398)
com.ibm.mq.MQEnvironment.hostname = hostName;
7. ERROR in /com/pegarules/generated/activity/ra_action_validateinfrastructuremq_a4456390d5ac62291bddd3f19a033d1c.java (at line 399)
com.ibm.mq.MQEnvironment.channel = channel;
8. ERROR in /com/pegarules/generated/activity/ra_action_validateinfrastructuremq_a4456390d5ac62291bddd3f19a033d1c.java (at line 400)
com.ibm.mq.MQEnvironment.port = port;
9. ERROR in /com/pegarules/generated/activity/ra_action_validateinfrastructuremq_a4456390d5ac62291bddd3f19a033d1c.java (at line 401)
10. ERROR in /com/pegarules/generated/activity/ra_action_validateinfrastructuremq_a4456390d5ac62291bddd3f19a033d1c.java (at line 402)
11. ERROR in /com/pegarules/generated/activity/ra_action_validateinfrastructuremq_a4456390d5ac62291bddd3f19a033d1c.java (at line 404)
com.ibm.mq.MQQueueManager qMgr = null;
com.ibm.mq cannot be resolved to a type
12. ERROR in /com/pegarules/generated/activity/ra_action_validateinfrastructuremq_a4456390d5ac62291bddd3f19a033d1c.java (at line 411)
qMgr = new com.ibm.mq.MQQueueManager("");
12 problems (12 errors)
Compile failed.
When I checked in PDN it is asking about below jar files to be installed:
com.ibm.mq.jmqi.jar
com.ibm.mq.jar
com.ibm.mq.pcf.jar
com.ibm.mq.headers.jar
com.ibm.mq.commonservices.jar
connector.jar
We are using Websphere and by default in the classloader path these jars are already installed.
4 - Extension - com.ibm.ws.bootstrap.ExtClassLoader
file:/opt/websphere/85/appserver/installedConnectors/wmq.jmsra.rar/com.ibm.mq.commonservices.jar
file:/**/websphere/***/appserver/installedConnectors/wmq.jmsra.rar/com.ibm.mq.connector.jar
file:/**/websphere/***/appserver/installedConnectors/wmq.jmsra.rar/com.ibm.mq.headers.jar
file:/**/websphere/***/appserver/installedConnectors/wmq.jmsra.rar/com.ibm.mq.jar
file:/**/websphere/***/appserver/installedConnectors/wmq.jmsra.rar/com.ibm.mq.jmqi.jar
file:/**/websphere/***/appserver/installedConnectors/wmq.jmsra.rar/com.ibm.mq.pcf.jar
So, do we have to install these jars any other shared path.
Saikat
Hi Sai,
You can follow the instructions specified over here to check the whether these jars were being picked or not.
Hope it might help you.
Regards
Mahesh
