Pega Robotics with Remote Desktop
Hi. We got the following two questions on using Pega Robotics on the remote desktop:
1. Can Pega Robotics, RDA and RPA, work properly in the thin client machine using remote desktop on the Windows Server?
2. Can the robot that worked fine in the environment above be properly migrated to the other environment?
Any thoughts on how we can answer these questions?
Moritaka Kanai
1. Pega Robotics can work properly running a machine that you access via Remote Desktop. It cannot control any applications running on another computer that you access via Remote Desktop. Basically, as long as you are running Runtime on the computer where your applications are running, you would be fine.
2. This robot would be fine to run on another desktop assuming the versions of the applications are identical on another machine.
