CDM 6.7 Upgrade to CDM 6.9 (backwards compatibility)
We are in the process of upgrading foundation server from 6.7 to 6.10 and are running into issues running CDM 6.7 due to class conflicts. My guess is that CDM 6.7 is not compatible with 6.10 due to a lot of tech stack upgrades. As such, I was looking at upgrading to CDM 6.9 as well. However, that poses a problem for us because we have several applications that will still need to use CDM 6.7 for some time while we are working on the upgrade.
So my question is, if I upgrade the DB schema for CDM from 6.7 to 6.9, will the 6.7 CDM code still work ? In other words is the database schema upgrades for CDM 6.9 backwards compatible to CDM 6.7.
Thanks.
Why are you looking for upgrading DB schema from v6.7 to v6.9 only but not the EAR files v6.7 to v6.9 ?
