Data Page with REST Connector as Data Source - Parameter Detection
We have a data page whose data source is a REST connector. It takes as parameter 'Idcompany' which is required, as you can see below:
This data page is the page context of some sections as you can see below:
Our problem is sometimes the value of the parameter 'IdCompany' is empty.
When the parameter is empty, we do not want to call the Connect-REST (since it generates unnecessary errors at the level of the Integration)
Is there a way to implement this requirement and how ?
Any small help will be greatly appreciated:)
Thank you in advance,
Mariane
Mariane
You can use multiple data sources. When you add another data source you will be able to use data source based on condition.
Please let me know if this is not clear, i will put a screenshot together.
Thank You
Raju
