HCL Technology
Last activity: 4 Oct 2016 17:05 EDT
Preview trimmed version Report Rules in FW Layer Vs Implementation Layer
When we receive requirement on report is most generic. We may develop the report rules in FW layer. Intially, I thought it should be run in FW Layer application. But What happened is, I open the report rule in FW layer by log into impln layer application. Now I am able run report, But What I wonder is, the source of table is refer from FW layer and data are coming from Impln layer table.
We have seperate table for both FW layer and implementation layer.
Alagar
Sounds like you are querying cases using an FW-layer Report Definition that has "Report on descendant class instances" checked in the "Data Access" tab. If you were logged into your FW-layer Application and had created cases at the FW layer your report would show you those cases. However, it appears you have only created cases at your Implementation layer. When you log into your Implemenation layer Application you add new rulesets at the top of your ruleset stack. Within those added rulesets are case type classes that extend/inherit-from/descend-from your FW-layer case type classes. The FW-layer Report Definition has the ability to recognize this situation. Rather than issue a query for FW-layer cases it will issue a query for Implementation layer cases.
