Ministerio de Justicia
ES
Last activity: 6 Oct 2025 13:09 EDT
How to check user identity after SAML SSO authentication
We configured an SSO in our Pega app using a SAML Authentication Service. Users log in providing a personal certificate or a password. Once authenticated, somewhere in the business process (due to security requirements) we need to ask the user for credentials again in order to validate those against IdP (same used in SSO). Our doubt is how we could manage this with Pega. We are in Pega Infinity '24.2.2.
Our requirement is quite the same as this:
Invoke SAML post SSO as a step up authentication | Support Center
Our First Approach
IdP team provided us with a new federation for (something like) a re-authentication. So, we configured a second SAML Authentication Service pointing to new IdP metadata. We configured a button to call the new SAML Auth. Service to validate the identity. The result is user is not asked to introduce certificate or password again. Instead, the user gets into the app with no extra validation. Is there a way we could force this second call to the SAML Auth. Service?
@Ramond16772579 you can’t “force” re-prompting from Pega alone; the IdP must honor a fresh login. Here’s the workable setup. Create a second SAML Authentication Service for step-up and set ForceAuthn=true and a stricter RequestedAuthnContext (exact match) like MFA/smartcard. Ask the IdP team to enforce “require fresh authentication” for that federation (ignore existing SSO session/cookie) or set an IdP policy that ForceAuthn on this SP app always triggers re-verification. From your flow, launch SP-initiated SAML by calling Data-Admin-Security-AuthenticationService.pzInitiateSAMLWebSSO with the step-up auth service name and pass a RelayState back to your case/assignment. On ACS success, use the post-auth activity to validate the asserted user/attributes against the current operator and set a “step-up verified” flag on the case/session. If the IdP won’t enforce ForceAuthn, your only alternatives are logging out (pxRequestorLogoff) or using a different IdP app that always prompts—both are clunky. The key is IdP policy + ForceAuthn + RequestedAuthnContext.
