Pega SI Constellation, Class structure for new application wizard
Hello all,
We are trying to create an application through wizard using SI Constellation as built on application (c
Once necessary case types and data objects for SI are selected, give application name and click on advanced configuration
From advanced configuration, I can see classes getting created as grp1 (interaction) and grp2 (SI case types) as shown below.
No matter what I tried, the classes will be created as Grp1 and Grp2. I don't want Interaction or Grp1 classes to be created. Only classes like Work-Activity (I mean in that way classes should be created).
Share your thoughts on this please.
Hi @NK Bitta,
As Smart Investigate Agentic Automation is built on Pega Customer Service application, and PegaCS-Work and PegaCS-Work-Interaction being the core classes they must be used for structured implementation approach.
Sheetal
