Filter relationship is not populating in report definition
Hi
I have sub report which results one of the property called Type. I need to use this property (Type) as a filter in main report when i try to use this property as a filter in main report filter relation is not populating it was just showing blank. Please Let me know if any answers.
Attached screenshot for reference.
Yasvanth T.
Hi @Yasvanth Tanuku,
I guess their might be a configuration issue in subreport on data access tab.
While configuring sub report we need to specify where the columns are going to be used (see below)
Also you need to provide alias to the sub report columns and use the alias in main report.
Hope it helps! Let me know if it works.
Thanks, Ankit
