Areteans
Last activity: 7 Apr 2025 9:51 EDT
JavaScript Compilation Issue for Embedding JS for LangChain
Langchain, a popular AI based engine, simplifies the integration of LLMs with external data sources, APIs, memory, and workflows, enabling developers to create context-aware, dynamic, and intelligent AI applications.
We are trying to embed the LangChain JavaScript Libraries for the use of BPM workflows. But we are getting an issue during compilation of code in the Text File Rule of type JS.
@Joyce Jenifer please check the Pega GenAI™ Frequently Asked Questions and documentation for limitations.
I would suggest you log your issue as an incident via the MSP.
Common Causes of JavaScript Compilation Issues in Pega Text File Rules
The issue you're experiencing is likely related to one of the following:
import { something } from '@langchain/core') may not be supported in the Pega JavaScript environment.Recommended Solutions
Solution 1: Use CommonJS Import Syntax
Instead of ES Module imports, try using CommonJS require statements:
Solution 2: Bundle Libraries Before Importing
Pre-bundle LangChain and its dependencies using a tool like Webpack or Rollup, then include the bundled file in your Pega application:
npm install @langchain/core @langchain/openainpx webpack --config webpack.config.jsSolution 3: Use IIFE Format Libraries
Look for IIFE (Immediately Invoked Function Expression) versions of LangChain libraries which can be directly included without import statements.
Solution 4: Check JavaScript Version Compatibility
Ensure your Text File Rule settings are configured to support modern JavaScript:
Then add your JavaScript code to the main tab, ensuring it uses syntax compatible with the JavaScript environment Pega supports.
Additional Considerations
References:
