Maantic
Maantic
Maantic
Posted: Feb 20, 2025
Last activity: Feb 24, 2025
Last activity: 24 Feb 2025 8:51 EST
Mainframe Partial Screen Matching Issue
Interrogated partial screen in the Mainframe application using Pega Robotics Studio V22.1.31 but it's not matching in the Palette. Also, updated the Match Region as Simple even though it’s still not matching in the Palette.
Please need your advice on the same.
@AsvinthS17189176What is your match rule for the partial screen? That entire line appears blank. You'll likely need a RegEx pattern to match in case that area gets populated by values. Perhaps there is whitespace or something between the areas where data might appear that you can use.
