LTFS
Last activity: 22 Aug 2024 11:12 EDT
Apache-Tomcat SSLException error
We are getting below exception in Apache tomcat catelina.out logs
Exception Cause: java.lang.RuntimeException: Unexpected error: java.security.InvalidAlgorithmParameterException: the trustAnchors parameter must be non-empty :: Exception while Axiom Post 3.0 API call --> javax.net.ssl.SSLException: Unexpected error: java.security.InvalidAlgorithmParameterException: the trustAnchors parameter must be non-empty
@AmitT17230856
The error "java.security.InvalidAlgorithmParameterException: the trustAnchors parameter must be non-empty" indicates that the trust store used by your application does not contain any trusted certificates. Ensure that your trust store is correctly configured and contains the necessary trusted certificates.
SSL error in Tomcat 8 Catalina logs
Connect REST fails with SSL
Using prpcServiceUtils to connect remotely to Pega environment running on Tomc
please log a support issue via the MSP if you need further help.
