Last activity: 9 Jul 2024 9:21 EDT
Field values in UI Paragraph rule- Constellation
In the UI Paragraph rule I see that I can embed hardcode links and properties , however how do we refer to field values ( from App studio) as I see its read only from the Dev studio? Any help on his would make it easier for us to reuse screens here there are exactly same fields with different labels.
Thanks and Regards,
Samiran.
Eclantiqx Digital Private Limited
To refer to field values from App Studio in a UI Paragraph rule, you can use the Insert property icon in the text editor menu. This allows you to reference field values from App Studio and reuse screens with exactly the same fields but different labels.
Updated: 25 Jun 2024 11:32 EDT
@Sindhu Nalajala - Did not get it. Can you please put in some screenshots ? I have tried using the Properties ( Insert Field) but not getting the field values in the dropdown. Let me know.
PL
@Samiran Manna please see on attached print screen how to reference a Field. If your Field (property) is not available in a dropdown it means it was not configured as Relevant Record. Please see more details on Academy: https://academy.pega.com/topic/managing-relevant-records/v2
Ramesh Sangili
@Kamil Janeczek - I am not sure if I get you correctly. I am trying to show a Rule-Obj-Field Value instance , not a property.
Rules created -
1. Rule-Obj-Field Value instance - XYZ (@baseclass)
2. Inside XYZ I have mentioned - What is your full name?
What I want - In the instructions (Rule-UI-Paragraph) when I refer to XYZ it simple shows me XYZ at runtime, however what I want is to display - What is your full name? instead of XYZ. Let me know if that is possible.
PL
@Samiran Manna your post has been tagged with Constellation tag. Can you confirm that you use Constellation based application?
@Kamil Janeczek Yes I am using Constellation based Application.
@Samiran Manna Paragraph rules are not supported in Constellation.
Paragraph Rules | Instruction text for forms, field groups, and fields is now configured at the View level. | Use the Case designer in App Studio or Dev Studio to configure instruction text at the form, field group, and field level.
For more information, see Configuring forms and Configuring field group |
Updated: 5 Jul 2024 4:36 EDT
@RameshSangili - Rule-HTML-Paragraph is not supported however Rule-UI-Paragraph ( at View level) is supported . I want to understand how to reference a Rule-Obj-FieldValue instance inside a Rule-UI-Paragraph. Hope the question is now clear? I have given a scenario in my previous reply to Kamil. Please check and let me know.
@Samiran Manna - Any updates?
