Symptoms
- After adding AllCoveredResolved ticket to a parent case, it remains unresolved even when all its child cases are resolved.
- Unresolved child cases, whose parent case is resolved, are routing an SLA to broken queue.
Errors
- Trying to save an invalid page: The cover open count is incorrect; it is -1
- Trying to save an invalid page: page is not valid
Explanation
A defect or configuration issue in the user operating environment.
Environment
The issue was reported in the following environments:
- Pega Platform™ 7.2 on-premises
- Pega Platform 8.3.1 on-premises
Solutions
To update the status of the parent case to Resolved-Complete:
- Add a utility shape before the end shape of the parent case flow.
- Set the AllCoveredResolved ticket on the utility shape.
Also, it is recommended to:
- Refactor design to avoid the use of tickets. Instead use the change stage functionality to move exception processing to an alternate stage.
- Limit advance flow processing to a single flow.
- Advance to a shape in a subflow only when the subflow is started.
- Limit flow to a single stage and not across stages of flows. A ticket cannot be raised from a later stage to an earlier stage in which the ticket is referenced.
- Ensure that the ticket is set in the flow that the case will be in when the ticket is raised.
Related Content
Product Documentation
Responding to business exceptions in a flow
